Is there any way to import a track plan made with another program? There is a track plan for the Granite Gorge & Northern Atlas layout that was made using AnyRail (www.anyrail.com, which I was not aware of) and I'd like to import it into RailModeller. Here's the link to the forum thread on this which includes the track plan to download:
https://www.anyrail.com/forum_en/index. ... 4e886a8da4
Thanks in advance.
Importing Trackplans from Other Programs
Re: Importing Trackplans from Other Programs
Unfortunately, direct import of layouts created by other track planning apps is not possible due to the lack of public file format compatibility. However, you can work around this limitation by exporting an image of the layout from the other app and then importing it into RailModeller Pro. This image can serve as a starting point for your planning process.
