group/ungroup function
menno
Post by menno »
After a set of elements combined to a group it and can't be ungrouped. Anyone who has the same problem?
Regards, Menno
Hermanrail
Re: group/ungroup function
Post by Hermanrail »
Yep - tried all sorts of combintions - menu items seem permenantly greyed out and the keyboard shortcuts don't work.
However - if you select the "delete" tool (the 'X') you can delete individiual items of a group if that helps.
menno
Post by menno »
But using the deletes option 'X' should delete the entire group, not just one element of it. I think some bug fixing is required here.
rmeiklej
Post by rmeiklej »
I've had the same issue - I'm reverting to v4 but really want v5 to work so I'll persist with what is effectively beta testing
Bergen
Post by Bergen »
Grouping/ungrouping seems to work fine in 5.0.4 beta 1. Can someone confirm?
The grouping should work fine since 5.0.3 (current App Store version).
Any remaining issues you find can you please send to the support e-mail address with the layout you've found it in?
Much appreciated,
