After a set of elements combined to a group it and can't be ungrouped. Anyone who has the same problem?
Regards, Menno
group/ungroup function
- Hermanrail
Re: group/ungroup function
Yep - tried all sorts of combintions - menu items seem permenantly greyed out and the keyboard shortcuts don't work.
However - if you select the "delete" tool (the 'X') you can delete individiual items of a group if that helps.
But using the deletes option 'X' should delete the entire group, not just one element of it. I think some bug fixing is required here.
I've had the same issue - I'm reverting to v4 but really want v5 to work so I'll persist with what is effectively beta testing
Grouping/ungrouping seems to work fine in 5.0.4 beta 1. Can someone confirm?
The grouping should work fine since 5.0.3 (current App Store version).
Any remaining issues you find can you please send to the support e-mail address with the layout you've found it in?
Much appreciated,
Much appreciated,
