Issues with selection vs adding
Nom
Post by Nom »
Using RailModeller Pro, I'm finding some issues with adding vs selecting track:
(All this is using the LGB track library)
Add vs select
  • Sometimes I cannot add track to a selected piece of track I just added. It highlights as if it will be added, but it doesn't add when clicked. I have to click in empty space to deselect in order to add track.
  • Very small pieces of track do not seem to have a "selection" zone (e.g. 10080 straight and smaller), only an "add" zone. The only way I have found to select these tracks is to drag-select. Even once drag-selecting, I sometimes end up adding track rather than dragging the item. This is especially a problem when I'm trying to remove a small track from a gap - I can end up with multiple small pieces added on top.
  • Sometimes the '+' icon gets stuck. After this adding tracks to the indicated track doesn't work reliably.
  • Could 'esc' be used to deselect the current selection?
Shift-select
Shift-select selects all pieces of track from the currently selected track to the added track, if and only if only one piece was already selected.
  • Is there a way to choose whether I want to add one piece or several? Command-click (the usual Mac OS way to "add one" rather than "add group" doesn't seem to work. Sometimes I actually want two discrete pieces. (Workaround: shift-drag-select the 2nd track using the marquee)
  • Is there a way to add a chain if I already have multiple selections? Example: I want the chain A-B, plus the branch that comes from half-way between A & B
  • If I have a loop, is there a way to use shift-select to select the entire loop? It seems to just choose the shortest path?
Suggestion:
  • shift-select always extends selection by all connected tracks (if possible)
  • shift-drag adds to selection as per normal marquee rules
  • cmd-select always selects single track - this forces selection mode even if it would otherwise 'add'
Re: Issues with selection vs adding
Thanks for the feedback!
Nom wrote: 24 Aug 2020, 04:06
If this is reproducible it would be great if you could get in touch with our support and an example!
Nom wrote: 24 Aug 2020, 04:06 [*]Very small pieces of track do not seem to have a "selection" zone (e.g. 10080 straight and smaller), only an "add" zone.
You can either zoom in for more precise control or hold down option to temporarily disable the append feature.
If desired the append feature can also be permanently disabled in the app's preferences.
Regarding multi-select we're about to rework this including the ability to command-click for non-contiguous selection!
Nom wrote: 24 Aug 2020, 04:06 [*]If I have a loop, is there a way to use shift-select to select the entire loop? It seems to just choose the shortest path?[/list]
You could use the Select All Connected Tracks function to select an entire loop.
