When I'm requesting to build a helix with 2 loops and and hight of 20 cm, the programme always put 5 loops on 20 com?
Thanks for any advice on the matter
D.
Building helix seems not working properly
Re: Building helix seems not working properly
It should just work, even with a single loop.
Did you confirm the value you've entered with the Return or Tab key?
Throughout the app values will be interpreted only after the input field has been left, e.g. by tabbing to the next field.
