How can I draw my streets on the layout? If there is a draw function I haven’t found it yet.
New here, hope I’m not repeating a topic.
Drawing Streets
Tom Newby HO
Re: Drawing Streets
Update: Well here’s one way, although it’s a bit clunky. I exported my layout as a .pdf file and then imported it into TurboCad. With the layout in TurboCad I can draw straight lines, curved lines, circles, whatever I want. Only problem is you need to have the track layout pretty much finalized before going into cad, because you can’t return back into RailModeler. At least I haven’t figured that out yet. This may or may not work with other cad programs.
Re: Drawing Streets
Hello Tom,
you can use the drawing tools from the Shape popup or the various street systems bundled as track libraries (Joswood Streetsystems H0, Tomy Aurora/AFX HO, Faller Laser Street, ...) available from the library catalog (also for your convenience at https://www.railmodeller.com/libraries.html)
