Dear Railmodellers,
I bought a new version of RailModeller a few days ago.
I used the old version already. This new is great!
I just ask for help for a problem I can not solve.
- I select a flexible track. In "Element" I select "curved". I define the value "Curve Radius" and the value "Arc Angle". This opaction should give me the curved track element I defined. For example: a track of 60 cm. Radius with an arc of 15, 30 or ... but not. Unfortunately, I do not create the track element.
With the old version of RailModeller this was possible.
Can you tell me what's wrong? Or how to achieve my purpose.
See you soon, thank you very much
Create a curved track element using the flexible track
Re: Create a curved track element using the flexible track
Hello Carlo,
Did you get our support email from earlier this week..?
So when you bend the flex track to a curve does anything happen?
It appears to work fine when trying with the current version - maybe you can send the flex track part number you're trying to bend.
Dear Jan,
Incredible! Now works!
I just watched your video. I did the same things ... The important thing is that it works!
Soon, thank you very much
