Trying to set 60 mm track spacing -- HO T-Trak Standard
mikepwagner
Post by mikepwagner »
The HO T-Trak standard calls for 60 mm track spacing.
From what I can tell, there is no way to set/enforce track spacing in RailModeler Pro -- from what I can tell.
N T-Trak modelers can use a piece of Kato N-Trak doube track to align their track at the end of the modules -- the double track has 33 mm spacing, which is the N T-Trak standard.
I thought I could use some of the same trick -- using a Kato #6 turnout and a couple of pieces of other track (S-283, S-193, and S-290), I can create the two tracks that are 60 mm apart. I can use that to align the track at the end of a module -- and I am good to go.
What I would like to do is take that turnout and associated pieces of track -- group them together as an element, and then save that element somewhere so I can use it in multiple layouts.
Is there some way to save a track element to something like a private library so it can be used in multiple layouts?
Is there a better way to set track spacing in RailModeller Pro?
Re: Trying to set 60 mm track spacing -- HO T-Trak Standard
Hello Mike,
Have you seen the assistants, specifically the Parallel Track assistant yet?
Screenshot 2025-12-03 at 12.38.42.png (160.19 KiB) Viewed 11392 times
There's also much more info in the user guide, plus we offer various tutorials:
https://youtube.com/playlist?list=PLvD4 ... yXtn0vVArq
All the best,
mikepwagner
RailModeller Support wrote: 03 Dec 2025, 11:39 Hello Mike,
All the best,
I have not -- and that seems to to be exactly what I want. I will have to figure out how to use it.
A very big thanks!
mikepwagner
I may be using the parallel assistant incorrectly -- that is extremely likely.
But when I have a curved pieced of track on the layout -- say a Kato Unitrack 2-220 with a radius of 610 mm -- and then select a piece of curved track with a smaller radius -- say a Kato Unitrack 2-210 with a radius of 550 mm -- to be added as parallel, the new track gets added on the outside if the current track.
What I am trying to do is build an HO T-Trak corner module -- 90°of a 610 mm curve -- and 90° of a 550 mm curve inside of that -- two concentric ¼ circles.
Is there a way to specify on which side of the existing track I want the new track to be added?
mikepwagner wrote: 03 Dec 2025, 15:08 Is there a way to specify on which side of the existing track I want the new track to be added?
Absolutely, that's the function of the buttons in the dialog:
mikepwagner
RailModeller Support wrote: 04 Dec 2025, 07:21
Exactly what I was looking for — thanks.
