RailModeller Pro 6.4.26 — What's New
NewsBot
Post by NewsBot »
In this Maintenance Update:
RailModeller Pro 6.4.25 (12. Mar 2024)
• When editing tunnel sections the Option key now enables fine-tuning of the tunnel portal's position within a tunnel track.
• The Close Gap and Connect with Flex Track assistants now both handle connecting tracks on different levels automatically grading the inserted tracks.
• Minor improvements in the Community Layouts browser and improved Touch Bar functionality.
RailModeller Pro 6.4.24 (5. Jan 2024)
• Resolved an intermittent error in the Track Helix assistant accessed from the Smart Insert pop-up menu in the toolbar.
• Enhanced filtering capabilities in the Stock dialog.
The release also includes various minor enhancements, bug fixes, and updates to the bundled libraries for track systems and accessories
RailModeller Pro 6.4.23 (20. Dec 2023)
What's New in this Maintenance Update:
• The Baseboard Assistant features a new triangle template and has improved usability and visuals
• Arc Baseboard Borders have been reworked for easy border radius editing through dragging and a simplified inspector
• The Baseboard Border inspector has been simplified, now labeling both border points in the layout for easy reference
• The Track Helix assistant has been redesigned for improved usability and now includes an option for attaching a ramp track at the helix exit
• The Parallel Track assistant has been redesigned offering more control over placement of the parallel track and now featuring an enhanced preview
• Layer Preview functionality has been optimized, enabling seamless transitions between previews of different layers
This release also includes several supplementary bug fixes, along with updates to the bundled libraries for track systems and accessories.
RailModeller Pro 6.4.22 (8. Nov 2023)
• Enhanced handling of parallel track pieces in functions that create a grade to the selected track and grade a section of connected tracks.
• The reworked detection for track selections not suitable for editing track grades now provides more actionable guidance and recognizes a wider range of scenarios.
• The enhanced Element Properties inspector now also displays grade or angle values for multiple items, when all tracks share common settings.
• The updated inspector for user-generated bumper (buffer stops) decorations, which can be added to any straight, curved, or flex track, now supports the direct entry of the bumper distance from the end of the track for both single tracks and selections of multiple items
• New base textures have been added for the 3D mode, and an issue with track base texture rendering on specific Mac systems has been addressed.
Additionally, a new button has been added the welcome window, allowing users to conveniently send support emails alongside the existing help menu function.
Furthermore, we have resolved a bug related to the use of a custom grid color.
RailModeller Pro 6.4 adds
