RailModeller Pro 6.4.24 — What's New
NewsBot
Post by NewsBot »
RailModeller Pro 6.4.24 (5. Jan 2024)
In this Maintenance Update:
• Resolved an intermittent error in the Track Helix assistant accessed from the Smart Insert pop-up menu in the toolbar.
• Enhanced filtering capabilities in the Stock dialog.
The release also includes various minor enhancements, bug fixes, and updates to the bundled libraries for track systems and accessories
RailModeller Pro 6.4.23 (20. Dec 2023)
What's New in this Maintenance Update:
• The Baseboard Assistant features a new triangle template and has improved usability and visuals
• Arc Baseboard Borders have been reworked for easy border radius editing through dragging and a simplified inspector
• The Baseboard Border inspector has been simplified, now labeling both border points in the layout for easy reference
• The Track Helix assistant has been redesigned for improved usability and now includes an option for attaching a ramp track at the helix exit
• The Parallel Track assistant has been redesigned offering more control over placement of the parallel track and now featuring an enhanced preview
• Layer Preview functionality has been optimized, enabling seamless transitions between previews of different layers
This release also includes several supplementary bug fixes, along with updates to the bundled libraries for track systems and accessories.
RailModeller Pro 6.4.22 (8. Nov 2023)
• Enhanced handling of parallel track pieces in functions that create a grade to the selected track and grade a section of connected tracks.
• The reworked detection for track selections not suitable for editing track grades now provides more actionable guidance and recognizes a wider range of scenarios.
• The enhanced Element Properties inspector now also displays grade or angle values for multiple items, when all tracks share common settings.
• The updated inspector for user-generated bumper (buffer stops) decorations, which can be added to any straight, curved, or flex track, now supports the direct entry of the bumper distance from the end of the track for both single tracks and selections of multiple items
• New base textures have been added for the 3D mode, and an issue with track base texture rendering on specific Mac systems has been addressed.
Additionally, a new button has been added the welcome window, allowing users to conveniently send support emails alongside the existing help menu function.
Furthermore, we have resolved a bug related to the use of a custom grid color.
RailModeller Pro 6.4.21 (5. Sep 2023)
• The Edit Baseboard tool now allows for seamless corner-to-corner snapping of baseboards, improving precision and ease of use
This release also features some bug fixes as well as updates to the bundled libraries for track systems and accessories.
RailModeller Pro 6.4.20 (1. Aug 2023)
New in this maintenance update
• The Tape Measure Tool has been improved with snapping functionality attaching the start and end of the ruler to nearby joints and baseboard border points, a new option to limit the ruler to the horizontal or vertical axis and 45-degree angles, plus an updated design for increased usability.
• JMRI Export has been updated to now support turntables and parallel (bridge) track elements, as well as improve the export of wye turnouts and level crossings.
• The inspector for user-generated buffer stops now shows the offset from the end of the track for improved control of placement
In addition, minor improvements have been made to the Cloud Catalog and Height Profile View.
This release also contains updates to the bundled libraries for track systems and accessories.
RailModeller Pro 6.4 adds
Other changes in version 6.4 include
If you have any questions about or issues with our app please get in touch with us using the Help > E-Mail Support menu command in the app, using the contact form on our website or just send an email directly to support@railmodeller.com
