Can I convert one manufacturers track for another?
All things related to the free edition of RailModeller
OrlandoAl
Post by OrlandoAl »
Have the Express version of the software at present and have found some plans/layouts that I like the look of, however they are using Arnold track in their plans. I would like to use Peco streamline, is there any way to have RM convert from the Arnold track to the Peco streamline code 80 for me?
Or do I have to redraw the layouts from scratch?
I will need to make some changes to the layouts I have come across, so will have to purchase the Pro version anyway, but thought I would take a look around at the free version initially to get the feel of things.
Thanks in advance
Alan
Re: Can I convert one manufacturers track for another?
Hi Alan,
Arnold and Peco use different track geometries (as most manufacturers do).
hope this helps,
OrlandoAl
Post by OrlandoAl »
Hello Jan,
Thank you for the reply.
Yes I appreciate that different manufacturers tracks are not the same as each other. Hence my question.... Can either RailModeller Pro or Express look at a plan and then convert or replace from one manufacturers track to another?
If not then not a problem, I will have to redraw the layout with the manufacturers track that I want to use.
I was seeing if it could be automated?
Thank you
Alan
