I am looking to open and put in image elements to help serve as a deisgn reference and list visual areas on my layout planning. The problem is they are always opened and sent to the very bottom of the layers box, and in order to make them visible on top of other elements such as my benchwork I need to bring them to the top of the layers.
The problem is no matter what, I can't seem to bring them up, and the program won't allow them to, even if the other layers are unlocked. Any idea of this is fixable, and has anyone else had this issue?
Cant move image layers from bottom to top of layers.
A_RMRP_Planner
Re: Cant move image layers from bottom to top of layers.
Hello A_RMRP_Planner,
The order of image and baseboard layers can be controlled similar to changing the order for regular layers.
The app does however ensure that layers with regular layout elements are always drawn on top of image and baseboard layers. When adjusting the order of image and baseboard layers they can be freely positioned within other layers of the same type, they will however always have a position in the layer list lower than any regular layer with layout elements.
You can find more details in the Rendering Order of Layers chapter in the manual!
A_RMRP_Planner
Hey thanks, I understand better now. I will read into it.
