Importing Rail Stock
Things that do not fit anywhere else
jrbburg
Post by jrbburg »
Hello,
I have a list of my Marklin C tracks. I can't import them into RailModeller Pro.
I know I have to save the file as .csv but it won't import.
Do I need to list the tracks in a particular way?
I'm not technical so need an idiot's guide please.
I subscribed to Railmodeller Pro 5 years ago and have never go over this first hurdle.
Many thanks
Re: Importing Rail Stock
The content of the stock can be imported from and exported to a CSV (character-separated values) file.
The CSV import and export uses a plain text file format with three fields:
  • Product Number
  • Library
  • Count
The fields are separated by a TAB or ; character.
The Product Number and Library fields must match the name of a RailModeller library and product number in the library.
If no matching element can be found when importing a CSV file the entry will be ignored.
Easiest way to get a template for importing is to just export a minimal stock with a couple of elements.
You can also find more details in the "The Stock" section in the manual.
