Bug: 'close gap' screen disappears when losing focus
Posted: 28 Jan 2015, 22:52
When RailModeller is searching for a connection using the 'close gap' function, and you switch to another application, or even click on the layout, the searching window disappears. But it does keep searching in the background. This becomes obvious when after some time suddenly a popup appears saying no connections were found, and it is also confirmed by the cpu usage.
And because the search window disappears, it means you can even start a second search while the first one is still busy. I think this is the cause of some application crashes where I had multiple searches going simultaneously.
So I think..
1) the search window should stay open when it loses focus
2) the 'close gap' menu option should be grayed out while the search window is open
This is in beta 4 by the way.
Also the application sometimes crashes when you try to quit RM while it is searching.
So I think..
