group/ungroup function
Posted: 10 Jan 2015, 12:43
by menno
After a set of elements combined to a group it and can't be ungrouped. Anyone who has the same problem?
Regards, Menno
Re: group/ungroup function
Posted: 10 Jan 2015, 14:01
by Hermanrail
Yep - tried all sorts of combintions - menu items seem permenantly greyed out and the keyboard shortcuts don't work.
However - if you select the "delete" tool (the 'X') you can delete individiual items of a group if that helps.
Posted: 10 Jan 2015, 14:42
by menno
But using the deletes option 'X' should delete the entire group, not just one element of it. I think some bug fixing is required here.
Posted: 11 Jan 2015, 00:16
by rmeiklej
I've had the same issue - I'm reverting to v4 but really want v5 to work so I'll persist with what is effectively beta testing
Posted: 10 Feb 2015, 23:37
by Bergen
Grouping/ungrouping seems to work fine in 5.0.4 beta 1. Can someone confirm?
Posted: 11 Feb 2015, 16:53
The grouping should work fine since 5.0.3 (current App Store version).
Any remaining issues you find can you please send to the support e-mail address with the layout you've found it in?
Much appreciated,
