Bug: selection frame does not match selected track when using smart insert/parallel
Things that do not fit anywhere else
Bergen
Post by Bergen »
When adding a piece using Smart Insert > Add as Parallel Track, then changing the track distance and toggling the side, the selection frame is wrong. It doesn't match the selected track piece. Video: https://www.youtube.com/watch?v=jiaoNVY13iw
Bergen
Re: Bug: selection frame does not match selected track when using smart insert/parallel
Post by Bergen »
Also confirmed fixed in beta 4. Nice work Jan. ;-) Only the little circles at the corners of the selection are a bit blurry on a retina screen. They are low resolution I think.
Thanks for the heads up, I'll put it on the to-do list!
