Cannot move track or other objects with the mouse
gnfan 2018
Post by gnfan 2018 »
I am having a problem where I can select an object on the plan but cannot move it. I can rotate it, delete it and move it using the arrow keys on my keyboard but I cannot move it (drag) around using the mouse. I can add a new track but once it is on the plan I can’t move it around using the mouse either.
I tried just quitting the application and restarting but it does the same thing. I restarted the whole computer and then launched Rail Modeller. It worked for a few pieces of track and then started with the same issue. Again being unable to drag a piece of track or any object around using the mouse.
I can however, move baseboards around using the mouse.
Naturally this makes layout design impossible to do.
Any idea as to what is causing this and how to resolve it?
Is there some setting I have changed inadvertently?
Mac OS 14.5
Rail Modeler Version 6.4.27 (Build 1525)
DavidB
Re: Cannot move track or other objects with the mouse
Hi David,
it appears our support emails didn't reach you?
We responded a couple of days ago but have not received a reply. Could you please check your spam folder and email settings to ensure our messages are getting through?
..first thing you could always check:
If you've configured RailModeller Pro on your Mac to use the Fixed mode for the canvas (see The Drawing Canvas section in the app's User Guide) it has to reject any content exceeding the canvas size you've specified for the particular layout in the Document settings in the sidebar.
The app will show an appropriate message in the status bar at the bottom of the window that case
canvas size abort.png (863.85 KiB) Viewed 36889 times
All the best,
Miamistax
Post by Miamistax »
Ian,
I'm having the same problem. I have Version 6.5.4 (Build 1583) running on MacOS Sequoia 15.3.1 (24D70). My Canvas Size Mode is set to Auto-Resizing.
Jeff
Jeff,
can you describe the type of layer, tool used and the steps to replicate so I can investigate?
