SCALEXTRIC | Big issue with C8295 Elevated Cross Over
david oxford
Re: SCALEXTRIC | Big issue with C8295 Elevated Cross Over
Post by david oxford »
Thanks, Jan :)
Local Hero
Post by Local Hero »
Great news Jan,
Thank you very much
david oxford
And proof that it's good in the now-available 6.2.5:
Screenshot 2020-02-15 at 20.04.51.jpg (49.68 KiB) Viewed 25172 times
Local Hero
Oh!!! this is a wonderfull new.
david oxford
With R3 curves, the equivalent pattern is:
Screenshot 2020-02-16 at 23.11.11.png (74.36 KiB) Viewed 25161 times
Personally, I prefer "transition curves", where you lead in gently and get tighter, before leading out gently again. (e.g. R3 then R2 then back to R3). I still need to work out the pattern for that though!
Local Hero
David,
I have found another isuue but I don't have permission to publish a new issue.
I have tried but I can't.
I have tried to design the attached Scalextric Set with RailModeller Express but there are a gap and I can't close the Set.
Captura de pantalla 2020-02-16 a las 21.02.42.jpg (255.27 KiB) Viewed 25155 times
david oxford
Are you sure it's RailModeller that is wrong, though?
You have one diagonal half-straight, which is hard to balance out exactly. Also, a gap that small is usually closeable in practice due to the track's flexibility.
Local Hero
Hi David,
I am not sure who is wrong.
You are wright about closing the gap.
NOTE 1:I took that Set from:
https://www.slotcar-union.com/es/fun-tr ... 4-set.html
NOTE 2:
I don't know what is a diagonal half-straight.
Thank you for your help
david oxford
This is a half-straight (C8207) and is on a diagonal. It's hard to make things match up exactly when you have an odd number of diagonal pieces, in general.
My conclusion is that the RailModeller version of this is probably right.
