Working with roundhouse
JackX
Post by JackX »
Hi!
Just bought the pro-version, and I´ve got an issue with Freilassing roundhouse & Marklin turntable.
1) Freilassing: Is there an option allowing each element to connet to each other? I´ve got 5 * 5 lokschuppen (on each of my 2 turntables), and I´d love to learn how they all (at least the 5 lokschuppen in each installments) could simultaneous move when I´m moving one of them!
2) Turntable: When adding tracks to the turntable, these tracks do not "follow" when I´m "turning" the table itself ??!
Any solution appreciated1
Cheers!
JackX
Re: Working with roundhouse
Hi JackX,
JackX wrote: 24 Jan 2019, 10:37 1) Freilassing: Is there an option allowing each element to connet to each other? I´ve got 5 * 5 lokschuppen (on each of my 2 turntables), and I´d love to learn how they all (at least the 5 lokschuppen in each installments) could simultaneous move when I´m moving one of them!
At this point only tracks connect to other tracks.
You can however group elements if you'd like them to keep their relative position.
JackX wrote: 24 Jan 2019, 10:37 2) Turntable: When adding tracks to the turntable, these tracks do not "follow" when I´m "turning" the table itself ??!
Rotating or moving (or any operation in general) always affects the current selection.
If only the turntable is selected then no other object in the layout will move or rotate when changing the turntable.
You can use the 'Select Connected' function or double-click any track to quickly select all connected tracks.
JackX
Post by JackX »
GREAT! Works as a charm :)
Cheers!
JackX
Gajewski
Post by Gajewski »
JackX wrote: 24 Jan 2019, 10:37 Hi!
Just used these fantastic payday loans and bought the pro-version, and I´ve got an issue with Freilassing roundhouse & Marklin turntable.
Cheers!
JackX
Can you have as many groups of elements as you want or is there a limitation on how that works btw? I hope I'm explaining myself well enough.
Gajewski wrote: 01 Feb 2019, 11:36 Can you have as many groups of elements as you want or is there a limitation on how that works btw?
Groups can be hierarchic, i.e. you can create groups of groups (of groups..)!
Hope that helps,
MoPac
Post by MoPac »
I am having a hard time to fit the allotted roundhouses with the Tomix fine scale track is there a away you can produce the Tomix roundhouse for Railmodeler Pro? Thanks!
MoPac wrote: 10 Dec 2019, 13:28 roundhouses with the Tomix fine scale track
We've added the Tomix 4053 roundhouse to the 'Roundhouses N' accessories library for the upcoming 6.2 update!
Roundhouses N.png (161.47 KiB) Viewed 21622 times
MoPac
Post by MoPac »
Thank you for the reply! I can't wait to use them on my design. Also I couldn't find the Rokuhan Z scale roundhouse either.
Best regards Clayton.
