Couple of thoughts - moving from AnyRail
Posted: 18 Aug 2017, 20:30
Hi, I've been moving from Anyrail as I use a Mac and want a Mac native app and really like this app. A couple of small items that I'm not sure if you plan to support or not which I find really useful in regards Flex track:
1. When editing a flex track allow a key/mouse combo to ensure the re-size of the flex track keeps it straight. At the moment if I double click to go to edit mode and shorten or stretch flex track it will bend not stay straight. On Anyrail I would hold down the shift key and drag and it would not bend.
2. Show the radius or set a minimum radius. On Anyrail I can setup my plan with a 12" minimum radius. Any track that I connect or bends with flex track that are less than 12" would show as red - warning.
3. Ability to cut flex track at any point. I've found this useful on any occasions. Cutting it makes it into two piece of flex track which I can then manipulate.
Just a couple of thoughts
Trevor
Trevor
