feature requests
Posted: Thu 15. Jan 2015, 18:46
by fpm_michael
Maybe there is a way to do this already, or a feature that is in the works, but I would love to have a "On Hand" inventory. Being able to work with the track that I own and track that I need to buy would be awesome. A custom track list would get me part way there (Only showing the track I have) but there is still no count on those sections. Pulling from an inventory list would better let you work inside of a budget and still maximize the stuff you already own.
Re: Suggestions and Feature Requests
Posted: Sat 17. Jan 2015, 07:19
the Stock (inventory) will be back soon, with support in the Parts window to show only tracks not in the stock (i.e. need to be purchased) and filtering the library catalog by stock contents.
Hope that helps,
Posted: Sun 18. Jan 2015, 17:45
by hans
It would be great if it would be possible to export a layout as XML. I actually need a feature that is rather peculiar to Slotcar system: We found that it is easiest to build a certain track if we have a linear list of the pieces that constitute it. If there was an XML export option, I could generate the required listing myself. Even a partial export would be helpful for that.
